Quelle huile dans les ammortisseurs Armstrong ?
- Iznogoud
comment faites vous pour refaire une de ces merveilles de la technologie moderne ?
Quelle huile ? En quelle quantité ?
Y a t-il des joints à changer ?
Merci par avance de m'apporter vos lumières.
Louis.
PS : Vous allez voir que même sur ce sujet, Arthur sait TOUT !
Louis.
Modifié en dernier par Iznogoud le 12 sept. 2006, 10:00, modifié 1 fois.
Invité
Once upon a time, a long time ago, near the mythical village of Birmingham, there were 2 identical twin brothers - separated at birth - who were destined to shape the lives of many, many thousands of future British car owners.
One of these brothers was born "visually challenged" - and was called "Lucas". Lucas became quite bitter, and dedicated himself to ensuring that everyone else should have some insight to his world of darkness. The other brother - who exhibited large amounts of upper body strength - was known as "Armstrong".
The story of Lucas is well documented (mostly in Braille). This is part of the story of Armstrong - the younger, and stronger, brother - who went on to pioneer shock absorber damping to generations of British vehicles.
Armstrong - although credited with huge amounts of upper body strength - had little or no stamina (due, I think, to a genetic design defect). He was able to resist and contain huge forces - but generally only for a short period of time. Left under physical stress for any length of time, he would, without warning, spew copious amounts of a substance resembling light oil from his armpits. It was this socially unacceptable personal behavior which I believe prevented him from attaining international acceptance in the motoring industry:- this behavior remains a repeatable mystery to this day by all his siblings & descendants. This weakness - not unlike the fabled Achilles and his heel - is know in medical circles as "Armstrong armpit".
Sprite owners front shocks appear to be descendant from "Rear Admiral Armstrong"- known as "Lefty" to his mates - a distant relative, who, unfortunately lost an arm in a horrific naval accident. Although physically different in appearance, these single arm front shock absorbers also exhibit "Armstrong armpit". It should be noted that all big and little Healey rear shock absorbers are descendants of "Lefty".
I am not aware of a permanent cure for "Armstrong armpit" - other than rebuilding by a competent expert - or replacement with rare NOS items.
- Arthur
Salut Louis (Hi Luis)
Pour l' huile (concerning the oil):
http://www.dynolite.fr/MOTORASP/Dynolit ... &famille=2
http://www.penrite.ch/Sortiment/Sortiment-f.htm
Au niveau de la soupape (for the valve)
là, je passe (I am not involved).
Salutations (regards)
Georges (George)
Georges (George)
- Pierre NOEL
Louis,
Mon expérience au sujet de ces charments accessoires est que quand ils commencent à pisser, c'est qu'ils sont malades. il ne faut pas se laisser attendrir.
Ce qu'il faut leur mettre dans la tête, ce n'est pas de l'huile pour tenter de les sauver mais une balle calibre 12. A mort !!!
Pour leur succéder, les "recon" ont mauvaises réputation.
Martin P. m'a fournit des Armstrong d'époque (Ils sont beaucoup plus mieux solide que ceus nouveaux qu'on fait maintenant, dit il) avec une garantie anti-crevaison d'un ans. Cela fait 3 mois et c'est toujours OK.
Pierre
Pierre
- Arthur
re
ai pas trouvé, mais cela traine sur le web.
Par contre :
http://www.chicagolandmgclub.com/drivel ... /jasw.html
(perso je suis plus prudent que sur les photos, je place en plus une couverture sur le ressort et pour être certain, je l'attache avec un câble à un point fixe et solide de la voiture)
http://www.nosimport.com/shoxcatalog.htm
En relisant John Twist et d'autres : l'huile classique est de l'huile de fourche moto 20W, le truc est de remplir avec de la 50W, p'être un poil plus dur (...) mais cela devrait moins (voir plus du tout) fuir si la fatigue n'est pas trop prononcée.
Par contre :
- Jean-Christophe B GT
- alan
- année : 1923
Invité
- alan
- année : 1923
- Iznogoud
Merci pour l'annonce, mais ce sont des arrières.
Les défaillants sont à l'avant sur mon auto.
J'ai démonté l'engin, retirer la petite plaque à 8 visses, empli d'huile de boite (monograde 30W), refermé et cela marche !
Merci de vos conseil.
Modifié en dernier par Iznogoud le 14 sept. 2006, 07:52, modifié 1 fois.
michel
