j'ai eu une discussion par mail avec Martin : il confirme tout à fait ma démarche (X2 les degrés ET la vitesse de rotation):
les valeurs qu'il valide sont bien :
Avance centrifuge 41730, quelque soit l'indice A,B, D ... :
0° jusqu'à 800tr/mn
15-19° @ 2400
18-22° @ 2800
28-32° @ 5600
l'avance à dépression (7-13-3 pour allumeur soit 7-13-6 pour vilebrequin) s'active à 7 pouces de mercure
est maxi à 13 pouces de mercure
l'avance maxi provoquée est de 3° (6°)
Extrait de nos échanges
Hi Philippe ,
Oui absolument ! both centrifugal & vacuum x 2.
Regards
Martin Jay
01984 629540
Distributor Doctor Ltd
Unit 8 Old Brewery Road
Wiveliscombe
Taunton
Somerset
TA4 2PW
> Martin, do you confirm I am right when I double your Distributor degrees AND
> Distributor RPM to obtain crankshaft degrees AND crankshaft RPM, some members
> are doubting ...
> I think I must also double the vaccum advance to get it in crankshaft degrees ?
> Thanks in advance.
> Philippe
> Selon Martin Jay <
martin@distributordoctor.com>:
>> Hi Philippe,
>> I have read your posting & I hope that will help the forum members .
>> The distributor advance information on the internet is full of errors ,
>> so many mistakes , I never trust it .
>> We have the original Lucas factory Test Data books.
>> Regards
>> Martin Jay
>> 01984 629540
>> Wiveliscombe
>> Taunton
>> Somerset
>> TA4 2PW
>> On 23/08/2016 10:34, Philippe wrote:
>>> Thanks a lot Martin,
>>> I doubled the degrees and rpm in order to express "crankshaft"values in my
>> post
>>> to forum members.
http://www.mgcontact.eu/phpBB2/viewtop ... 0&start=20
>>> I am surprised wrong information are given on several non official sources
>> as
>>> you can see here :
http://www.mgb-stuff.org.uk/curvestext.htm ...
>>> Kinds regards,
>>> Philippe
